so i have been trying to get this to work for weeks now, running into problem after problem.
Currently, im trying to run arcgis engine runtime 9.3 on red hat .
under root i get this error
Could not load native libraries. ArcGIS/bin should be added to LD_LIBRARY_PATH environment variable
java.lang.UnsatisfiedLinkError: /home/nhieuduong/arcgis/bin/libntvninv.so: libshlwapi.so: cannot open shared object file: No such file or directory.
ive checked and libntvninv.so is in the /home/nhieuduong/arcgis/bin directory. so is it saying that it cant find libshlwapi.so ? i followed all the procedures outlined by arcgis on there website. sourced the init_engine file and the init_java file and placed java home env variable in the java directory. my regisitration is complete. i have the correct licenses. did anyone encounter something similiar that can maybe shed some light as to what is going on?
