Hello all:
I am trying to use the Version namespace in VS Express 2010 to bind my standalone application to the Desktop runtime. Adding the reference doesn't seem to be a problem however when building the code I get this error message:
The type or namespace name 'Version' does not exist in the namespace 'ESRI.ArcGIS' (are you missing an assembly reference?)
//Calls to needed assemblies
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.DataSourcesGDB;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Version;
using System;
Executing the code fails, obviously,since the calls to this namespace aren't recognized.
No troubles with other namespaces in this case just the Version namespace. Are there any particular settings I should modify in VS Express?
Suggestions or thoughts?
Thanks in advance
Darrin
