C# Visual Studio Express 2010 Version namespace not recognized
700
05-08-2012 07:29 AM
DarrinBlaisdell
Hello all:
I am trying to use the Version namespace in VS Express 2010 to bind my standalone application to the Desktop runtime. Adding the reference doesn't seem to be a problem however when building the code I get this error message:
The type or namespace name 'Version' does not exist in the namespace 'ESRI.ArcGIS' (are you missing an assembly reference?)
//Calls to needed assemblies
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.DataSourcesGDB;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Version;
using System;
Executing the code fails, obviously,since the calls to this namespace aren't recognized.
No troubles with other namespaces in this case just the Version namespace. Are there any particular settings I should modify in VS Express?
Suggestions or thoughts?
Thanks in advance
Darrin
BKuiper
Set "Specific Version" on Esri.Arcgis.Version to false (properties on reference)
JohnHauck
The assembly name is ESRI.ArcGIS.Version but the namespace is only ESRI.ArcGIS
using ESRI.ArcGIS;
