Hi,For every iteration, I update my cost field and subsequently build the network dataset to reflect those changes. Following is the code I am using for building the network dataset.
Private Sub buildNetworkDataset()
Dim pWorkspaceFactoryM As IWorkspaceFactory
Dim pFeatureWorkspaceM As IFeatureWorkspace
Set pWorkspaceFactoryM = New ShapefileWorkspaceFactory
Set pFeatureWorkspaceM = pWorkspaceFactoryM.OpenFromFile("C:\data\", 0)
Dim pWSExtMgr As IWorkspaceExtensionManager
Dim pUID As New UID
Dim pWSExt As IWorkspaceExtension
Dim pDSCont As IDatasetContainer2
Dim pND As INetworkDataset
Dim pGeoDS As IGeoDataset
Dim pNB As INetworkBuild
Dim pReturnedExtent As IEnvelope
Set pWSExtMgr = pFeatureWorkspaceM
pUID.Value = "{4C1B151C-48C3-46C5-AB57-E6B941A1D00A}"
Set pWSExt = pWSExtMgr.FindExtension(pUID)
Set pDSCont = pWSExt
Set pND = pDSCont.DatasetByName(esriDTNetworkDataset, "Network_ND")
Set pGeoDS = pND
Set pNB = pND
Set pReturnedExtent = pNB.BuildNetwork(pGeoDS.Extent.Envelope)
End Sub
But it encounters a run-time error '-2147220937 (80040237)': Automation Error at the very last line:
Now, I can't figure out what is wrong with the code. Can anybody help me on this?Thanks,Nagendra
