Dim pFeatureSelection As IFeatureSelection pFeatureSelection = pFLayer Dim pEnumID As IEnumIDs pEnumID = pFeatureSelection.SelectionSet.IDs Dim id As Long id = pEnumID.Next Dim pPointCollection As IPointCollection Dim pFeature As IFeature Do While Not id = -1 pFeature = pFLayer.FeatureClass.GetFeature(id) pPointCollection = pFeature.Shape For lPnt = 0 To (pPointCollection.PointCount - 1) SetZValueOnPoint(pPointCollection.Point(lPnt), Convert.ToDouble(txtZValue.Text)) Next id = pEnumID.Next Loop
Public Function SetZValueOnPoint(ByVal point As IPoint, ByVal zValue As Double) As IPoint Dim zAware As IZAware Set zAware = point zAware.zAware = True point.Z = zValue Return point End Function ''inside main procedure: For lPnt = 0 To (pPointCollection.PointCount - 1) Dim newPoint As IPoint = SetZValueOnPoint(pPointCollection.point(lPnt), Convert.ToDouble(txtZValue.Text)) pPointCollection.UpdatePoint lPnt, newPoint Next '' Set pFeature.Shape = pPointCollection pFeature.Store '' id = pEnumID.Next
Hi Jeff,
Many thanks for looking at this!Please see the procedure code:Public Sub SetZValueOnPoint(ByVal point As ESRI.ArcGIS.Geometry.IPoint, ByVal zValue As System.Double) If point Is Nothing OrElse point.IsEmpty Then Return End If Dim zAware As ESRI.ArcGIS.Geometry.IZAware = CType(point, ESRI.ArcGIS.Geometry.IZAware) ' Explicit Cast zAware.ZAware = True point.Z = zValue End Sub
I am trying to develop arcgis 10.0 addin to update Z values of vertices of a selected line. Scenario: The tool scans all features in a given shape file and populates the list of features which has at least one vertex with a Z vlaue = 0. User then selects a feature from the list and clicks a button to update Z values to a given height - this last part does not work.
I have tried the following for updating Z values of a selected polyline feature with no luck:Dim pFeatureSelection As IFeatureSelection pFeatureSelection = pFLayer Dim pEnumID As IEnumIDs pEnumID = pFeatureSelection.SelectionSet.IDs Dim id As Long id = pEnumID.Next Dim pPointCollection As IPointCollection Dim pFeature As IFeature Do While Not id = -1 pFeature = pFLayer.FeatureClass.GetFeature(id) pPointCollection = pFeature.Shape For lPnt = 0 To (pPointCollection.PointCount - 1) SetZValueOnPoint(pPointCollection.Point(lPnt), Convert.ToDouble(txtZValue.Text)) Next id = pEnumID.Next Loop
Please your help in providing any hint or suggesting error in the code above is much appreciated!
Hi Jeff,
