ArcGIS Engine Attribute Editor does not honor visible property in Fields tab
1930
11-06-2014 05:30 AM
ThavitinaiduGulivindala
I am developing an ArcGIS Engine 10.1 based application.
I have to display only couple of fields visible to the customer for editing and the remaining fields are edited internally by the application. I have created a map document using ArcMap and set the visibility of fields in 'Fields' tab of 'Layer Properties' dialog in ArcMap. The ArcMap Attribute Editor displays only the visible fields for editing which is expected. I have used the same mxd in ArcGIS Engine based application and the Engine Attribute Editor displays all fields ( does not honor visible property) for editing.
Out of curiosity, I have checked the 'Identify' command in Engine and this respects the visible property.
Is this the expected behavior or a bug.
Thanks in advance.
Reply
