AoInitialize Initialize crash
384
07-12-2017 05:49 AM
YevgeniLepa
I'm trying to run the Geoprocessor with IIS express and I use AoInitialize  before I run the process.  After a while the code line below crashes the system without any error indication or a com exception:
" aoInit.Initialize(esriLicenseProductCode.esriLicenseProductCodeArcServer)" . I can't find any indication or documentation for that.
ArcObject version: 10.4
ArcGisServer version: 10.4
YuanLiu
You probably did, but just to double check, did you make sure to compile your project targeting 64bit?
