"Table was not found" exception
634
01-29-2013 05:17 PM
IlyaSolovyev
ArcGIS for Desktop 10.1 SP1
ArcObjects .NET SP1
Windows 8 (russian)
Visual Studio 2010
When I try to open feature class with russian symbols (e.g. "????????_???????") from file geodatabase programmatically (fws.OpenFeatureClass(name)), I get an "Table was not found" exception. Also I tried to open feature class with name in uppercase - same result.
Any ideas?
MarcinDruzgala
ArcObjects .NET SP1
Windows 8 (russian)
Visual Studio 2010
Any ideas?
Well I suggest you to list all feature classes that are in the specified dataset and then use OpenFeatureClass method.
public List<string> listFeatClassInDataBase(Geoprocessor GP, string GDBPath , string Dataset) {      //lista      List<string> list = new List<string>();      GP.SetEnvironmentValue("workspace", @GDBPath);       IGpEnumList fcs = GP.ListFeatureClasses("*", "", Dataset);      string fc = fcs.Next();        while (fc != "")       {            list.Add(fc);            fc = fcs.Next();        }        return list; }  private void SomeMethod() {  List<string> featureClassList = listFeatClassInDataBase(GP,GDBPath, datasetName);   foreach (string feature in featureClassList)   {   if(feature == "????????_???????")   {    featWorkspace.OpenFeatureClass(feature);   }  } }
More about listing data
Debugg this and check what's your feature classes names, maybe there is a problem with russian symbols.
Regards
MDruzgala
MarcinDruzgala
ArcObjects .NET SP1
Windows 8 (russian)
Visual Studio 2010
Any ideas?
Regards
MDruzgala
IlyaSolovyev
Your solution works fine, thanks.
But why does my implementation lead to such a strange behaviour of FeatureWorkspace?
        public List<string> GetAllFeatureClassNames()
            List<string> names = new List<string>();
            // Featureclasses in datase
            IEnumDatasetName enumDSNames = (_featureWorkspace as IWorkspace).get_DatasetNames(esriDatasetType.esriDTFeatureDataset);
            IDatasetName dsName = null;
            while ((dsName = enumDSNames.Next()) != null)
                IEnumDatasetName dsFCNames = dsName.SubsetNames;
                if (dsFCNames != null)
                    IDatasetName dsFCName = null;
                    while ((dsFCName = dsFCNames.Next()) != null)
                        if (dsFCName.Type == esriDatasetType.esriDTFeatureClass)
                            names.Add(dsFCName.Name);
            // Featureclasses in root
            IEnumDatasetName enumFCNames = (_featureWorkspace as IWorkspace).get_DatasetNames(esriDatasetType.esriDTFeatureClass);
            IDatasetName fcName = null;
            while ((fcName = enumFCNames.Next()) != null)
                names.Add(fcName.Name);
            return names;
