I can add a table as an XYEventSource from an Access database, with the following code. This works. My problem is described after the code block.
srWorkspace = ao.OpenAccessWorkspace(dataSource);
srTable = ao.OpenTable(srWorkspace, "MyTable");
IDataset dataSet = srTable as IDataset;
IName tableName = dataSet.FullName;
IXYEvent2FieldsProperties xyEvent2FieldsProperties = new XYEvent2FieldsPropertiesClass();
xyEvent2FieldsProperties.XFieldName = "myX";
xyEvent2FieldsProperties.YFieldName = "myY";
IXYEventSourceName xyEventSourceName = new XYEventSourceNameClass();
xyEventSourceName.EventProperties = xyEvent2FieldsProperties;
xyEventSourceName.EventTableName = tableName;
ftrLayer = new ESRI.ArcGIS.Carto.FeatureLayerClass();
SpatialReferenceEnvironment spatRefEnv = new ESRI.ArcGIS.Geometry.SpatialReferenceEnvironmentClass();
IGeographicCoordinateSystem geoCS = spatRefEnv.CreateGeographicCoordinateSystem((int)ESRI.ArcGIS.Geometry.esriSRGeoCSType.esriSRGeoCS_WGS1984);
geoCS.SetFalseOriginAndUnits(-180, -90, 1000000);
xyEventSourceName.SpatialReference = geoCS as ESRI.ArcGIS.Geometry.ISpatialReference;
IName xyName = xyEventSourceName as IName;
IXYEventSource xyEventSource = xyName.Open() as IXYEventSource;
IStandaloneTableCollection pTableCollection = map as IStandaloneTableCollection;
IStandaloneTable standaloneTable = new StandaloneTableClass();
standaloneTable.Table = srTable;
pTableCollection.AddStandaloneTable(standaloneTable);
ftrLayer.FeatureClass = xyEventSource as IFeatureClass;
ftrLayer.Name = "My Table";
map.AddLayer(ftrLayer);
The problem I'm having is that it's adding the table to the map as a feature layer with a feature class, and I don't want that. I want it to behave exactly as if the user right-clicked on the table in ArcMap and chose the "Display XY Data..." menu item.Right-clicking on the layer created as above and choosing Properties shows this for the source:Data Type: XY Event Source Location: C:\data\database.mdbFeature Class: MyTable_FeaturesFeature Type: SimpleGeometry Type: PointHowever, if you conduct the Display XY Data operation manually in ArcMap on a standalone table added to the TOC, the following shows for the source, and this is what I'm after:Data Type: XY Event SourceLocation: C:\data\database.mdbTable: C:\data\database.mdb\MyTableX Field: myXY Field: myYHas Object-ID Field: YesWhat in the world am I doing wrong?Thank you for any assistance!Mike
