ADDIN: Help needed detecting changes in layers
266
07-09-2013 01:32 AM
Hi everyone. Hit a problem with an AddIn I've almost finished developing. Without going into detail, I need the AddIn to respond to any changes in datasources on layers and stand-alone tables. Basically, my AddIn needs at least one feature layer and one stand-alone table to work, so it's toolbar buttons are disabled until the criteria is met. So far I have an extension hooked into the NewDocument and OpenDocument to interrogate the documents layers and their validity, creating two arrays of valid feature layers and valid stand-alone tables. This used to be in the tool's update event but the checking process had a significant affect on performance.
I hope someone can advise?
Thank you.
Reply
MVP Frequent Contributor
Andrew,
Sounds like you want to be hooking into the IActiveViewEvents Interface and capture when the map changes in someway.
Duncan
Reply
