10.0 Engine for .NET TOCControl Group Layer Not Updating
725
08-30-2012 11:40 AM
GlennNead
I have a MapControl with an associated TOCControl as a buddy.
Working with the underlying map, I can add a group layer programmatically.  The group layer shows up properly in the TOC.
Later I programmatically add child groups underneath the group layer as well as feature layers.  When control returns back to the viewer, the features are rendered on the MapControl, but the original group layer is unchanged, as if there were no child layers.  I can interactively change the visibility of the group layer which hides/shows the underlying feature layers, but I can't actually get to them.
If the layers are added to the map prior to displaying the controls, the layers show up properly in the TOC.
I've tried the refresh method on both the map and TOC controls.
[UPDATE:  Definitely an issue with groups.  If I add multiple group layers to the map itself, they show up in the TOC.  Layers under the group do not show in the TOC.]
Thanks in advance!
  -- Glenn
JohnHauck
Occasional Contributor II
After you add the layer to the group you can call Update on the TOC.
JohnHauck
GlennNead
Time for me to go home for the day.
Thank you.  I saw the refresh method on the control, but did not see the Update method.  That did the trick.
         -- Glenn
HarshGupta
New Contributor II
sir i populate all the feature layer in toc but unable to group that layer please help me out
