What's the maximum number of "Rings" one can do with a ring buffer tool?
608
02-17-2019 11:38 PM
Elijah
Occasional Contributor II
I tried doing a ring buffer in Arcmap 10.5.01 for 21 rings but it kept processing and never produced any feature. Tried this 3 times, same thing. I was wondering if there is a limit?
DanPatterson_Retired
What is the size of the raster and the buffer ring?  You may be just running into memory and processing issues.  Have your tried a smaller buffer ring size around a small feature?
Elijah
Thanks Dan,
The buffers are around a point feature, and the rings are simply 5km apart.
A total of about 21 ring are expected. I had thought it should be just easy.
I can provide the code if you want to try the python/numpy route.
But do consider the size of a 5000 m ring size.
What is the cell size you are using?  You can see how things get quickly out of hand .  Here are two buffer sizes with a 1 and 10 m cell size for a 5km and 20km diameter (2.5, 10. radii)
cell size   radius    buffer cells
1              2500 m  19,634,954 ish
10                            196,349
1               10,000 m   314,159,265
10                                  3,141,593
Now you say the rings are 5000m apart
1m cell size radius (2500*20), cells  => 78,539,816,339,745
10 cell size                                          => 785,398,163,397
Maybe switch your cell size to 100m or more
by Anonymous User
Not applicable
Check out this thread in Geonet if could be what you are looking for especially if you are using Python. I do not believe there is a limit to how many rings your buffer tool can create.
https://community.esri.com/thread/188054-arcmap-104-multiple-ring-buffer-05-m-arcpy
