Squares with rounded corners
440
11-20-2023 11:37 AM
MikeMedina
How do I draw a square with a rounded corners? I could do this in ArcMap, but I haven't found the way to do it in Pro yet. Thanks.
BrandonCranfield
Layout view will be in the Insert Tab and within the Graphics and Text Group. Hit the drop down arrow a few times and select the "Rounded Rectangle" right below the "Polygon" item.
Testing map notes real quick unless you're trying to add it to a feature class...
Edit after testing map notes:
You can add polygon map notes into the map, then change the symbology of the square with an exaggerated offset effect in the properties section/layers subsection.
Let me know if that works for ya!
BrandonCranfield
Are you talking about in layout view or map view?
MikeMedina
Preferably in Map View, but I could do either.
BrandonCranfield
MikeMedina
Brandon,
Thanks for your help. I'm still trying to find my way around ArcPro.
Sincerely,
Mike Medina
NC Geological Survey
