"Polygon To Raster” changes values
121
12-29-2020 05:58 PM
ZhenyuZeng
My original file has polygon data, and I use Polygon To Raster function. After I have done it, I found the value of the polygon data were changed.
The general steps are:
1. The last column of the table **Study Area Block Groups** is **PERC_UNDER5** like https://sm.ms/image/9Ozpej2G8XJHbLT
- 2. I used the ArcToolbox function of **Polygon To Raster** and in the **Input Features** chose the **Study Area Block Groups** with **Value field** of **PERC_UNDER5**
- 3. Then I ran it and made the results to display on the map
- 4. But the values of the result are different from the values of **PERC_UNDER5**. The values were showed as https://sm.ms/image/QnIwqT6tUFmBGde
How are these values of the picture of **children** derived?
I recorded it
FORESTWEBB
I am having the same problem.
