Is it possible to create a field which automatically updates its value?
2406
12-04-2020 07:35 AM
SilvanStöckli
Similar to the fields "Shape length" and "Shape area" which automatically update when you cut the polygon I’d like to create a field which automatically update when you change the value of e field in the same table. The calculation would base on several fields of the same table. Therefore, it would be like a field-calculator calculation which automatically starts when you change one of the values the calculation is based on. Is this possible?
tigerwoulds
Arcmap - No
ArcGIS Pro - Yes! Check out Attribute Rules to do this.
tigerwoulds
Arcmap - No
