How to name a output file based on input file and a user defined suffix and save the output file to a workspace?
769
05-14-2021 01:33 PM
badrinathkar
I am looking for a python code that allows me to name an output file(shapefile/dbf) based on input file +user defined suffix. Thereafter I would like to save the output file to a workspace.
DavidPike
MVP Frequent Contributor
via command line or as a python script tool?
without more info, something along the lines of:
import os
in_file = arcpy.GetParameterAsText(0)
output_workspace = arcpy.GetParameterAsText(1)
out_suffix = arcpy.GetParameterAsText(2)
out_name = os.path.basename
out_name += out_suffix
out_filepath = os.path.join(output_workspace, out_name)
DavidPike
import os
badrinathkar
As a Python script tool.
DavidPike
So will the above fit into your existing script? do you understand it etc.?
