Export Map failed error message "An unexpected error occured while trying to export the map"
1431
07-07-2020 01:54 PM
ChrisYoung2
I have been using this map for two years now and and exporting maps. It was working fine last week. Today, it started giving me this message. The map is data driven and uses online content. Any thoughts on how to fix this?
Tags (1)
DavidPike
MVP Frequent Contributor
Strip out the online content, this sounds like a cause - not the solution but at least it identifies the issue.
Try the MXD Doctor utility.
Give more details on your export settings etc.
ChrisYoung2
MXD doctor didn't do anything.
ChrisYoung2
So after reconstructing this map and testing it at all phases, I have discovered that the issue is when I create data driven pages. For some reason, I can not export pages that are data driven. Any thoughts?
