ArcMap 10.6 (Windows10) Failure when selecting polygons by rectangle
90
01-06-2021 11:56 PM
ClemensSchneider
Hi guys,
as a Student of Geography i use ArcMap for Desktop (10.6) on Windows 10. Everytime i try to do this, the system fails: Activate the button 'Select Features by Rectangle' in the Tools Toolbar. Select every polygon
which is not visible in the ancient map by pressing the Shift-Key.
Thanks for helping!
Tags (3)
Reply
RobertBorchert
Frequent Contributor II
it is probably a projection issue.  Are you using a regional projection?  Some your polygons may be out side of your projection area.  Copy the date to a new database with new feature dataset that is using a world wide projection
Reply
