Least-Cost - Wetlands
874
10-29-2019 01:03 PM
WillFeltz
Has anybody attempted to quantify wetland data and soil data for rate of resistance to estimate least-cost pathways? Many of studies I have seen put wetlands as high values, which I do not agree with for foot travel.
PaulPrevedoros1
Dear Will
The way I did it was to consider as time. I was working on Angkor Data, setup 1m grid and assumed a walking pace of 5km per hour which is equivalent to 0.8 sec/ metre.
Thus when you do you walking you consider time to move a metre.
Clue if you want to use 0.8 sec/ metre, multiple you costs by 10, then to get accumulated time divide time by 10
Works a treat.
Cheers
PaulPrevedoros1
Dear Will
I have found an equation that may help even better this was one version of the algorithm
https://en.wikipedia.org/wiki/Tobler%27s_hiking_function
the formal paper
or
http://geographianapocensis.acad-cluj.ro/Revista/volume/nr_2_2012/pdf/Magyari_Dombay.pdf
these equations can enacted using the raster calculator
Works a treat
PaulPrevedoros1
I have done some thing like this in Angkor. Difference was that in rice paddies are difficult to walk on regardless of whether the paddy is wet or dry, Thus the bunds where the preferred surface.
I worked on the stating point of 5km. Check the work of Waldo Tobler
https://escholarship.org/uc/item/05r820mz
or
DETERMINING MINIMUM HIKING TIME USING DEM
M.-S. Zsolt and D. ŞTefan
Geographia Napocensis 2012 Vol. VI Issue 2 Pages 124-129
and work from their logic.
I worked on the principle and experience people would avoid walking through wetlands especially is carrying stuff.
Cheers
paul prevedoros
