Using Survey123 with Workforce
2852
9
08-26-2019 11:58 AM
JeffHyder
How can I assign surveys submitted from Survey123 into Workforce? I have applications that have been submitted, now I want to assign those submitted surveys to my inspectors for them to edit and inspect. How can this be done and is it easy?
CraigGillgrass
Jeff,
This blog outlines one way you can handle this scenario:
Workforce and Survey123: Creating assignments in the field
Another, is to add the Survey123 feature service to the Dispatcher web map, so that your Dispatchers can create assignments from the features in Survey123.  However, with this workflow, it's not as easy to just get the information from Survey123 into Workforce.
Craig
JeffHyder
So, I have 7 surveys which are permit appplications where the end user fills out all of the information. At the end I have a permit granted field that is for office use only, that is also a relevant answer that opens questions on the survey after it is permited. Those are the questions I wish to assign to the inspectors to complete in the field with them having the customer's info right there in the application that they provided. How would I be able to assign those surveys to my inspectors to complete or edit in the field? They can open them through the inbox now but that shows all the surveys. I wish just to show the day's assignments.
CraigGillgrass
Jeff,
The surveys that you want to assign to the Inspector to open in Survey123, are these new surveys or are they pre-existing surveys?
From reading you reply, I think these are pre-existing surveys but would like to confirm.
Craig
JeffHyder
Pre-existing.
CraigGillgrass
Thanks Jeff, unfortunately, there really is no easy to support/solve this issue at this time.
The integration workflow between Workforce and launching other apps is targeted at the creation of new data.  Adding the ability to open existing data (features or surveys) is in our roadmap, but hasn't been assigned to a release.
Craig
PanGIS
Hi Craig Gillgrass‌,
do you know if there are news on this?
CraigGillgrass
Supporting this ability is something we're looking at for our 2020 plans.  I'll have a better idea closer to the User Conference on our plans to support this capability.
PatrickKent1
Hello @CraigGillgrass ,
Just found this thread from a few years ago and I am trying to implement the same thing. Is there any update on this capability?
Patrick
CraigGillgrass
We've made some updates in our December release that make this a little easier to accomplish but we have not implemented full support for it.  In December, we expanded the set of fields that can be passed from Workforce to the app being called.
In terms of changing our Workforce app integration to open existing features or inspections; this work has been parked for the time being.  We continue to review it each release to see if we can address it but it hasn't been added to a release yet.
You can accomplish this by editing the app integration table yourself and creating the url Survey123 requires. You'd have to look into the Survey123 documentation; they have several topics that describe how to do this.
Craig
