Can field values be saved as favorites?
843
09-10-2018 10:38 AM
CarlHolt1
When creating an Assignment, can field values be saved as favorites to minimize typing?
CraigGillgrass
Hi Carl, thanks for you question.
Could give an example of what values you'd like to have saved?  If you can also go into some details on when the need for this comes up, that would help us to understand your use case.
thanks,
Craig
CarlHolt1
Dispatchers are creating assignments every quarter for the same address for workers to complete a Survey123 inspection at that location. The only thing changing in the Create Assignments dashboard is the Due Date and ID. Too minimize clicks and typing I was hoping that a future enhancement of saving fields as favorites is possible.
CraigGillgrass
Hi Carl,
Thanks for following up and providing your use case.
One enhancement we're looking at is, the ability to copy or duplicate an existing assignment.  This would allow the Dispatcher to change the values for the new assignment.  Would this help in your use case?
Craig
CarlHolt1
Yes it would.
