Automatically generating assignments in Workforce
3193
14
07-10-2018 07:08 AM
RPGIS
Occasional Contributor III
I was wondering if there was a way to create assignments in Workforce automatically with survey123 or any other means without having to generate assignments manually. I am simply looking into automating certain tasks so any help would be greatly appreciated.
Robert
by Anonymous User
Not applicable
If you do
print(layer.query("1=1", out_sr=3857).features)
what does that print in your notebook?
Also, you have invalid attribute names. Anything that is
feature.attribute[]
needs to reference a field name in your layer. So your priority and description are invalid.
Also, the first parameter in
gis.map()
is a location that gets geocoded, so your map might not show since your string may be able to be geocoded.
RobbieEisenrich
New Contributor III
Thank you!!!!!
I worked through the steps you gave me and got it to work.  First did the print option but I got no output as you suspected. I then tired a different feature service with only one layer in it and this worked. I also adjusted the priority and description fields to match fields in my layer.
Such a cool tool! Thank you for putting this out there!
RobbieEisenrich
New Contributor III
Howdy,
So I am having one last issue. I am testing with another layer that does not have a address field (Location). Is it possible to pull the location from somewhere else or does the address field have to be present with any layer I am using ?
by Anonymous User
Not applicable
You could put any string in there.
RobbieEisenrich
New Contributor III
Howdy again,
I was able to get the location working. Would it also be possible to pass parameters through from a newly created field in the assignments feature service? I tested with a new field in various data types but kept getting a error with the name of the new field in the assignments layer I generated
