Allow Workforce for ArcGIS to pass GUID types to Survey123. For some odd reason, Workforce only allows you to pass data to fields that are of type "String" in Survey123 feature layer. Please add GUID types and perhaps other field types as well to the survey123 dropdown. This is essential for relating data since GUID types are often used to relate a primary table's GlobalID to a child layer's ParentGlobalID (guid) field.
In the screenshot below, I should see GUID types in the Survey123 Question dropdown.
Yes! This is such a LARGE overlook by ESRI. Most agencies use related tables to store their inspection / maintenance / service data.
Hello @GreggRoemhildt2 @KellyArmstrong
With the Workforce release that is happening tonight we will be adding the ability to pass all and any field to any of the apps such as Survey123, Collector or Field Maps. You should start to see GUID field types be available tomorrow.
Please let me know if you see any issues with this.
thanks,
Craig Gillgrass
esri
