I really need a calendar view for Workfoce, otherwise our partner is not willing to use the app. It would really help, if the assignments could be seen in a clear calendar view. It would be even better if there was an option to add an assignment to your (outlook/google) calendar app.
Planning your work and assignments from a calendar seems obvious, I think Workforce would really benefit from it. Both the dispatcher as well as the fieldworker should be able to add the assignments to their calendars.
I really hope you consider adding this 🙂
This would change the way we work as well. Right now we are fighting with teams because they are so used to seeing it in a calendar that they can't schedule their days without having that type of view.
Great suggestion!
A calendar or being able to link to Microsoft planner or Power Automation would be a huge time saver and make keeping tract of larger projects a lot easier.
Thank you for a great Idea!
