Workflow Manager AOI not showing in ArcGIS Pro
1760
10
07-13-2020 09:33 AM
Ulises
We used WMX in ArcMap in a daily basis and want to establish a migration path to ArcGIS Pro.  As part of our evaluation I set a Workflow Connection in AG Pro without major problems but I'm not able to see current AOIs in the Map.  Is there any considerations or configuration changes needed for Pro?  I haven't found any related documentation about it.
Any help is appreciated.
Ulises Feliciano Troche
XiaomengZheng
Pro shall work the same way as the Workflow Manager client.  The AOI function is still supported in Pro with the same configuration in the Workflow manager administrator. Would you please check your job's bookmark in Pro and see if the AOI bookmark existing?
Meggie
Ulises
Thanks for the feedback Meggie.  Job description in Pro says it has LOI Defined, but no LOI shows.
WMX app
Pro map
XiaomengZheng
It seems to be a map loading issue for me. I see you have totally 302 jobs in the current job query and your AOI map should be just loaded properly. Any error in your log?
You probably need to update the log level from default 3 to 5 to capture details.
Meggie
Ulises
Xiaomeng Zheng, attached the log file.  Don't see any specific errors...
XiaomengZheng
Yeah I do not find anything in your log either. Just curious, how many jobs out of the 302 jobs in your current job query having AOI? I noticed your current job's (2018-02120) location is quite small. What if you zoom in and can you see the AOI?
Ulises
Good day,
there are about 259 AOI created.  I zoom in several times without any success.
XiaomengZheng
What version of Pro are you using? I can give it a try.
Ulises
2.5.2
XiaomengZheng
I don't seem to be able to reproduce this issue. Could you please contact Esri Tech Support and they will work with you to look deeper into this issue. They may ask you to provide the data that you are using and try to reproduce this issue.
