Invalid raster dataset. Failed to create raster layer. Permission Denied. How can I overcome this problem?
18452
20
10-25-2018 09:45 AM
CaioMansini
New Contributor II
Hello everyone,
I'm having this issue with my ArcMap 10.6.1. I think it is probably a "permission" issue, because I cannot copy and paste files on ArcCatalog. How can I solve this? Any ideas?
Thanks in advance.
Tags (1)
XiaomengZheng
Thank you so much Dan!
ThomasBurke2
New Contributor II
I have the same problem.  We have raster files in fixed directory locations that we have used for with ArcGIS for the last two decades without any problems.  After upgrading to 10.6, we found that we can no longer access ANY of those files.  We get the message saying that we don't have access permissions.  But, by moving the files to a directory with a smaller path name, we can access them again.  So we are in the process of moving 10's of thousands of these files in hundreds of directories to new directories with path names that have to be so short that they are not going to make any sense to anyone in the future.  Plus, we are having to go back to all of our map files for the last 10 years and change the hard coded linkage to the new file locations.  Before we are done, this is going to have cost us about 100K to dumb down our directory structure to match ESRI's newly created limitations.  One step forward and three steps back, way to go ESRI.
DanPatterson_Retired
Windows supports file paths up to 260 characters without effort, assuming you are talking about local drives.  You would be hard pressed to exceed that.
With the move to Unicode in all software, new challenges exist.
Do you have examples where paths are causing issues?  Do they have spaces, dashes, periods or other flotsam? (numbers letters and the underscore are good)
ThomasBurke2
New Contributor II
Hi, below are two examples of one of the path names that will no longer work with ArcGIS.
I:\Generic CA GIS Data\County Data\Contra Costa County\DEM\ELE_CCC_DEM\ele_ccc_dem
E:\Canyon Road Bridge\Lidar Merged\hillsha_natu1
The first one has worked in for us in ArcGIS for years, but will no longer work with the latest ArcGIS.
Esri grids?
Output raster formats and names—ArcGIS Pro | ArcGIS Desktop
The name of an Esri Grid format raster has more specific restrictions:
  • The maximum number of characters is 13.
  • It cannot have spaces.
  • It cannot use special characters other than underscore ( "_" ).
  • For tools that output an Esri Grid Stack, the stack name cannot have more than 9 characters.
  • The total length of the name for a Grid and its path cannot be more than 128 characters.
So you are good on the file's name, the length is less than 128 characters... but your paths contain spaces and it wouldn't be the first time this has caused issues.
As a test try creating a folder (or copy and edit the path to a new drive) with the path spaces removed,
I:\Generic_CA_GIS_Data\County_Data\Contra_Costa_County\DEM\ELE_CCC_DEM\
As a more general reference, for the move to Unicode and other issues
https://community.esri.com/people/Dan_Patterson/blog/2016/08/14/filenames-and-file-paths-in-python
XuanFeng
Thank you for your reply!  It solved the problem whcih bothered me all afternoon.
ThomasBurke2
New Contributor II
We have done that, and it works, and we are being forced doing that, but we have hundreds and hundreds of directories and thousands of files that have worked fine for the past two decades.  I know Unix people are not allowed to use spaces in path and file names, but Windows has allowed spaces in names since the 1990's.  We do a lot of Windows programming in-house and there is nothing special to allow spaces in file and path names.  As a matter of fact, you have to go out of your way in your code to make sure that users can't insert spaces in their file names.  Its just poor programming.  ESRI has always had problems with excessive path lengths, and we have learned to live with that, but now they are screwing their whole Windows user base.  Apparently, so far, this great march backward is only with the group that has been working on their grid routines, as far as we can tell, all the other ArcGIS functions work just fine with spaces in the path and file names.
We actually had another meeting on this today.  Given the cost and the hundreds of labor ours required to go backwards, the general consensus is that it is probably going to be easier to just go back to Ver. 10.5.  Everything worked fine in that version, and we have yet to see anything in 10.6 and 10.7 that does anything for us.
You might also want to batch some conversion of the esri grids to *.tif files as backups when you are back in 10.5.
It is the preferred standalone raster format now and also avoids the sticky situation where a corrupt 'info' folder kills a bunch of grids associated with it.
And more importantly, you can batch it ...
Raster To Other Format—Conversion toolbox | ArcGIS Desktop
Saw no bugs BTW, but I would contact tech support in any event.
ThomasBurke2
New Contributor II
You are right.  tif format is better.  We usually try to use that, but sometimes when in a hurry, you forget to add the extension, and you get stuck with the esri grid format.  I usually realize it just as i am pressing return.
papayadennis
大家好,
我的 ArcMap 10.1 遇到了這個問題。我在這種情況下遇到了同樣的問題,因為我無法在 ArcCatalog 上複製和粘貼文件。我嘗試了上述方式,但問題仍然無法解決。我該如何解決這個問題?有任何想法嗎?
提前致謝。
