Invalid raster dataset. Failed to create raster layer. Permission Denied. How can I overcome this problem?
18475
20
10-25-2018 09:45 AM
CaioMansini
Hello everyone,
I'm having this issue with my ArcMap 10.6.1. I think it is probably a "permission" issue, because I cannot copy and paste files on ArcCatalog. How can I solve this? Any ideas?
Thanks in advance.
XiaomengZheng
Hi Caio,
Are you able to copy/paste other format data such as feature class or tables? If this only occurs to the raster, I would recommend you reaching out to Raster/Image Server and the issue might be related to the data you tried to copy.
Meggie
CaioMansini
Hello Meggie,
No, In ArcCatalog I do not have permission to copy anything on ArcCatalog. My Professor suggested that this might be a problem of "access" and recommended me looking for solutions here. Any ideas on how to overcome this problem? Or how to change permission in ArcCatalog? Because the following message is always "Permission Denied".
Thanks in advance.
DanPatterson_Retired
I suspect the permissions are controlled by your organization.
Where are you trying to copy/save stuff too?  Normally students are given full access to a subset of your local machine but denied access to other folders to prevent system/image corruption.
CaioMansini
Hey Dan, thanks for replying!
I'm trying to move the raster dataset into ArcMap. The folders are in my desktop, but I still can't drag the rasters into ArcMap.
The Professor said that these files are old and do not have any permissions assigned. Any ideas on how to change that or how to find the folder that I have permission to drag?
try not dragging... we restrict such things in certain circumstances.  Add the data manually through your Add data option
CaioMansini
Same error
could you specify the file's name and file path.
All I see is a folder highlighted in the c:\users.... folder and it is a path with spaces in it and Unicode characters.
I would suggest trying to copy it to a folder with no spaces and really simple... maybe c:\temp ….
And does the file have a filename extension? ie a *.tif. or is it the afpop2010_18 file?  if it is that one, then it might be an esri grid... which totally doesn't like paths with spaces or filenames greater than 8 or 10 characters (long time since I used them.  If it is an esri grid then it is lacking an info folder.  So you will need to find out what kind of raster it is
CaioMansini
Hi Dan,
Yes the file path is "C:\Users\caiom\OneDrive\Área de Trabalho\Assignment 3" (Do not mind the characters, I'm Brazilian, but my Windows is in English. However, for some reason the Directories are all in Portuguese and all other things in English).
I tried your suggestion and moved the files to the folder "C:\Temp\As3" and it worked. Is it an error related to the path name or is it because there is some issue about permissions in the TEMP folder? Because the OS allows anyone to access the temp folder without restrictions, this is a default config in Windows.
Thank you very much!
Glad it worked!  Pass it on.
Don't use paths and/or filenames with spaces.
They work sometimes to most of the time.
They will never work when you really need them too .
We also don't allow our students to store files in the C:\users... folder for a variety of other reasons.
We had IT set a specific folder (C:\Students) that students can make their own folders in and save their work.
The machines are routinely 'wiped' and reimaged except for files in that folder.
Good luck
