GPTool that's work as LauchGPTool and doesn't work as ExecuteGPTool
1940
10-08-2013 09:51 PM
sagihadas
I tried to set up a step to create a folder.
I used the GP tool: "Create Folder".
When I defined the step as LaunchGPTool it's worked as I expected and created the folder.
When I defined the step as ExecuteGPTool, the step worked but didn't create the folder.
The computer configuration is:
Win 7,
ArcGIS + WMX 10.1 sp1
Oracle 11G, SDE 10.1
would greatly appreciate it if you can help me.
Hadas
Reply
MichaelBroadbent
Hi Hadas,
Could you provide the arguments you have input for the ExecuteGP tool to create the folder?
Michael
Reply
sagihadas
Thanks Michael,
We got an announcement from ESRI that this problem is a known bug. We found a way to bypass the bug, by using a PYTHON script instead.
Hadas Sagi
Reply
ThavitinaiduGulivindala
ExecuteGPTool custom tool did not work but a sample, similar to ExecuteGPTool, is available in the installation directory . Building the .Net solution makes the custom tool appear in the custom tool selection window. And this works fine.
Reply
