Reading extended job properties
3190
05-14-2010 09:30 AM
RetoSchöning
I haven't found a way to read a value for a job's extended property. I can get the record from the container, but how can I get the field index for the property name (I would prefer not to hardcode the index)? There is an interface IJTXAuxPropFieldInfoSet which seems to be made for this, but I can't find where it is implemented. I checked all types in ESRI.ArcGIS.JTX via reflection, but that interface seems to not be implemented anywhere. Or is there another way how to get at those property values? Do I have to open the AuxRecordContainer as an ITable?
Here's the method I would like to implement. I'm using JTX 9.3.1 build 128.
private static int GetFieldIndex([NotNull] IJTXAuxRecordContainer recordContainer, [NotNull] string fieldName)
 // invalid cast:
 IJTXAuxPropFieldInfoSet fieldInfos = (IJTXAuxPropFieldInfoSet) recordContainer;
 fieldInfos.Reset();
 IJTXAuxPropFieldInfo fieldInfo = fieldInfos.Next();
 int index = 0;
 while (fieldInfo != null)
  if (string.Equals(fieldName, fieldInfo.FieldName, StringComparison.OrdinalIgnoreCase))
   return index;
  index++;
 return -1;
RetoSchöning
ok, once I have a record I can use IJTXAuxRecord.get_PropName(int index) to search for the property index. That works.
If IJTXAuxPropFieldInfoSet is implemented on some public class I would still appreciate a hint, I would prefer to look up the field indexes before accessing the records.
