Job is not running by non administrative user
2750
07-06-2012 05:55 AM
RajeshMane
ArcGIS Work flow manager doesn???t allow run the job other than administrator.  I have created a work flow manager USER schema as per documentation provided by ESRI. As per the test scenario there are two users in order to test the scenario. (Administrator and QA/QC user e.g.)
As per the process flow Administrator assigns a job to QA/QC user. USER1(administrator) is able to assign a job to USER2 but to when user2 logs in and tries to run the job as per actual flow, system doesn???t allow to perform the task. Toolbars are disabled. Actual steps are documented in attached document.
System Environment
ArcGIS Work flow manager Build 309
ArCGIS Desktop 10 ( ArcEditor )
ArcSDE 10, SQL Server 2008 R2
RajeshMane
Hi all,
This issus is resolved. It was a Post installation misunderstanding. Which leaded to issue.
