Can I change the color of LOI features in WMService_LOI.mxd ?
I tried it and got the message Unable to save. "Check to make sure you have the write access the the specified file..."
Thanks.
This happens to me somtimes and the only way I know to work-around it is to save it with another name in the same location. Then go back to the map document location and delete the original map and then rename the newly created map to have the original name.
Thanks Matthew. I was able to rename them successfully. I restarted my map service but js viewer still shows the old color. Look like I have to re-publish it. I have big demo on next Monday so I'm not sure I want to mess with it today 🙂
Again, thank you very much for your help.
I understand completely, I hope it works as expected when you attempt this work-around. Good luck on Monday
