Change color of LOI features in WMService_LOI.mxd ?
1227
09-22-2016 11:58 AM
helenchu
Can I change the color of  LOI features in WMService_LOI.mxd ?
I tried it and got the message Unable to save.  "Check to make sure you have the write access the the specified file..."
Thanks.
MatthewDuffy
This happens to me somtimes and the only way I know to work-around it is to save it with another name in the same location.  Then go back to the map document location and delete the original map and then rename the newly created map to have the original name.
MatthewDuffy
helenchu
Thanks Matthew.  I was able to rename them successfully.   I restarted my  map service but js viewer still shows the old color.  Look like I have to re-publish it.  I have big demo on next Monday so I'm not sure I want to mess with it today 🙂
Again, thank you very much for your help.
MatthewDuffy
I understand completely, I hope it works as expected when you attempt this work-around.  Good luck on Monday
