It should be possible in workflow manager to change the display size of the fields in the extended properties tab, or have the fields resize to fit the length of the text.
The problem that this would solve is as seen below that some time information in extended properties can be to long for the size of the field.
and there should be plenty of room to expand these field as can be seen in the image below.
Hi Rasmus,
This is in the product plan for the new service-driven architecture deployment of Workflow Manager where the string inputs are more responsive but still get cut off. We have an issue to allow the user to choose the display size.
Unfortunately it is not an easy enhancement for the traditional geodatabase version of the product due to limitations in the user interface.
Thank you for your contribution!
Michael
