Widget Icon Color/Alpha
7213
29
06-24-2015 08:21 AM
JayGeisen
New Contributor III
I'm hoping someone can point me in the direction of where I can go to change the widget icon color (alpha/transparency/etc)? Thanks
StanMcShinsky
Occasional Contributor III
Jay,
If you go to <app#>\themes\WidgetTheme\widgets\HeaderController\css\style.css and change the values in this part of the css around line 57 then you can adjust the transparency over the icons or other options.
.jimu-widget-header-controller .icon-node{
  cursor: pointer;
  opacity: 0.6;
  text-align: center;
  border-right: 1px solid #323e4f;
-Stan
MalcolmEchaluce
You will need to modify the .css of that widget.  If you go into your widgets/Query/css/style.css, you should be able to find the section for the widget icon to change some of its characteristics.
MalcolmEchaluce
Sorry, that was for the Query widget. Obviously, you'd go into the name of the widget instead, so widgets/WIDGET NAME/css/style.css.
JayGeisen
New Contributor III
Thanks for the reply, Malcolm. I've tried changing the settings in that file and it doesn't seem to affect anything. It must be set somewhere else.
RobertScheitlin__GISP
Jay,
   The widgets icon is in the widgets images folder (normally called icon.png), but you most likely already knew that. So are you asking about how to change the widgets placeholder background color?
JayGeisen
New Contributor III
Robert,
Yes, I believe that is what I'm trying to do. The icons themselves are white PNGs with transparent backgrounds, right? But when the page loads, they're displayed against the (in my case) black header as gray. And they change alpha values (or are they colors?) when you hover over them to white. I'm just wondering where the settings for these are.
Thanks
Jay,
  The color of the preload widget icon is controlled by the css. The way that I handled this is by adding some css rules to the particular theme color style.css for my app.
server\apps\11\themes\FoldableTheme\styles\olive\style.css
/* My Theme Style Adds */
.jimu-preload-widget-icon {
  position: absolute;
  cursor: pointer;
  border-radius: 4px;
  background-color: rgb(90, 107, 77);
  -ms-filter: "Alpha(opacity=20)";
  background-color: rgba(90, 107, 77, 0.2);
.jimu-preload-widget-icon.jimu-state-selected {
  -ms-filter: "Alpha(opacity=80)";
    background-color: rgba(90, 107, 77, 0.8);
.jimu-preload-widget-icon:hover{
  -ms-filter: "Alpha(opacity=40)";
  background-color: rgba(90, 107, 77, 0.4);
LindseyStone
This allowed me to change the widgets displaying over the map. And then going into the individual css file of the Home widget I was able to change the the color and alpha.  What about the plus and minus tool that zooms the map in and out so I can make them all match?
Lindsey,
.esriSimpleSliderDecrementButton {
    background-color: rgba(0, 0, 0, 0.4);
.esriSimpleSliderIncrementButton {
LindseyStone
Does anyone know if this special coding to change the icon transparency for the widgets on the map for the 1.2 app builder.  I had the below code working for WAB 1.1 version but it will not work in the 1.2 WAB version.
  1. /* My Theme Style Adds */
  2. .jimu-preload-widget-icon {
  3.   position: absolute;
  4.   cursor: pointer;
  5.   border-radius: 4px;
  6.   background-color: rgb(90, 107, 77);
  7.   -ms-filter: "Alpha(opacity=20)"
  8.   background-color: rgba(90, 107, 77, 0.2);
  9.
  10. .jimu-preload-widget-icon.jimu-state-selected {
  11.   background-color: rgb(90, 107, 77);
  12.   -ms-filter: "Alpha(opacity=80)"
  13.     background-color: rgba(90, 107, 77, 0.8);
  14.
  15. .jimu-preload-widget-icon:hover{
  16.   background-color: rgb(90, 107, 77);
  17.   -ms-filter: "Alpha(opacity=40)"
  18.   background-color: rgba(90, 107, 77, 0.4);
