Web Mapping Application not working after trying to get Basemap widget to work.
636
6
01-30-2019 08:20 AM
ChadFoster1
New Contributor III
I had a functioning web mapping application built in Web AppBuilder for ArcGIS.  The basemap widget was not displaying any basemaps for users.  I found the following thread, No Basemap Choices in WebAppViewer  and went to the settings and then changed the purpose to "Configurable".  I could not figure out what code to paste into the configuration parameters section.  I changed the purpose back to "Ready to Use" and saved.  Now if I try to view the application, i get this error.
If I try to edit using Web AppBulider, the page just stays on the loading screen.
What did I do?  and how can I fix it without redoing the entire Web Mapping Application again?
ArcGIS Web Application
Tags (1)
RobertScheitlin__GISP
Chad,
   The error complains about an unexpected token. so you must have made a syntax error in your change. Go back and double check your json file for syntax errors.
ChadFoster1
New Contributor III
If I knew how, I would. to my knowledge, I never made any changes.
Chad,
ChadFoster1
New Contributor III
I went on the Item Details for the Web Mapping Application < Settings < Web Mapping Application through AGOL.
I never put anything in the Configuration Parameters and then just changed back to Ready To Use and saved.
ChadFoster1
New Contributor III
I am now trying to view the json through ArcGIS Online Assistant, but it is not displaying the code for the Web Mapping Application.  It just keep trying to load
Chad,
   Sounds like you need to give esri tech support a call. It sounds like that change has introduced a syntax issue to the items json.
