Web AppBuilder with private map ask for login
2265
11
12-07-2018 06:03 AM
GuilhermePigosso
I have a WebApp Application that I created using the Web AppBuilder, that point to a private map under my organization.
My goal with this is be able to open the WebApp without login, but I is not working.
My proxy (I'm using the Java implementation) configuration is:
<serverUrl url="https://org.maps.arcgis.com"
   matchAll="true"
   clientId="XXXXXXXXXXX"
   clientSecret="ZZZZZZZZZZZZZZZZZ"
   username="user"
   password="pass"
   tokenServiceUri="https://org.maps.arcgis.com/sharing/rest/generateToken"
The Proxy seems that is working fine, but, when I try to open the WebApp I a box like this before see the WebApp:
Does anyone have any know what I am missing here?
Thank you in advance!
KierenTinning2
Did you ever get this to work? No matter what I do it fails.  Built the app from Web AppBuilder on ArcGIS Online - downloaded it to host on the internal network and always prompted for the username / password.
Even if I supply the Client_ID and Client_Secret with the token service, oath2 or neither used.  Interestingly enough, I can log into ArcGIS Online, but when prompted through the web app my login fails.
I had to add
"httpProxy": {
"useProxy": true,
"alwaysUseProxy": false,
"url": "https://xxx.xxx.xxx.xxx/proxy/proxy.ashx",
"rules": []
To the bottom of the config file as it wasn't available in the base app when I downloaded it
GuilhermePigosso
Hi Kieren,
Yes, I made it work, but being totally honest with you, I don't remember exactly all that I did.
But, anyway, my current configuration is something like this:
On proxy side I have this configuration:
<serverUrl url="https://myportal.maps.arcgis.com"
   matchAll="true"
   username="myuser"
   password="mypass"
   tokenServiceUri="https://myportal.maps.arcgis.com/sharing/rest/generateToken" />
<serverUrl url="https://static.arcgis.com"
   matchAll="true"
   clientId="client_id"
   clientSecret="client_secret" />
And my proxy is:
"httpProxy": {
    "useProxy": true,
    "url": "",
    "rules": [
        {"urlPrefix":"https://myportal.maps.arcgis.com/",
            "proxyUrl":"/Proxy/proxy.jsp"},
        {"urlPrefix":"https://static.arcgis.com/",
On this setup is working as expected. I hope it helps you
