Web AppBuilder stops allowing you to save configuration.
14739
34
09-28-2015 10:55 AM
PaulDoherty2
Occasional Contributor III
Has anyone else had an issue where you suddenly can no longer make new changes to their web mapping app in Web AppBuilder? All of a sudden the "Save" button is stuck on "Saved"? It is probably a known bug, but does anyone know of a workaround other than starting over?
LeoQuayle
Thats add a custom widget by the way....
RobertScheitlin__GISP
Leo,
   So the error exists in the custom widget. What custom widget? Is the widget developed for the same version of WAB that you are using? Are there any errors in your web browsers web console?
LeoQuayle
HI Robert
Thanks for your assistance. Your first response has confirmaed that the error is in my custom widget…That a start for me. The second is it pointed me to the consol which shows a whole host of errors…. Doh! I have a bit of learning to do! All I wanted was a widget which would offer me a dropdown menu of items to select from. I was then going to see if I could get a map symbolised using the option selected (but that was another step…) See the config log below
Leo,
   As this is off subject for this post now I would suggest starting a new thread if you need further help.
LeoQuayle
Ok. Thanks Robert.
Leo
DianaWalker1
New Contributor II
I have the same problem with a web app, where all the data is in AGOL.  I did the resizing of the web browser and the save became active again.
Thanks Richard for figuring this out!!!
JulieRoebotham
New Contributor III
Just out of curiosity - for those who were seeing this happen - was the web app one that had ever originally been 'saved as' from an original web app? like - it started as one web app, then you Save-As to another name and repoint to a new map?
DavidWendelken
Not for me.  Always started from a new app.
PramodHarithsa1
..and this still happens. Resizing the window saved. Thank you!
Don_Barker
New Contributor III
Still happening here, too.  In an app that was created from original, not Saved As.  No custom widgets.  AGOL version of WAB.
I tried all the workarounds listed above:  Resizing, Chrome, Firefox, Edge.  Cannot save the next edit.  Am starting over.
