WAB Print Widget will not print while location widget is active
456
06-15-2017 11:52 AM
ChristopherSchreiber
Occasional Contributor II
Hello all,
If you utilize the Print Widget while the "GeoLocation" widget is active, the print widget fails immediately.
It does add this to the Web_Map_as_JSON property though:
   "id":"map_graphics",
   "opacity":1,
   "minScale":0,
   "maxScale":0,
   "featureCollection":{
      "layers":[
            "layerDefinition":{
               "name":"pointLayer",
               "geometryType":"esriGeometryPoint"
            "featureSet":{
               "geometryType":"esriGeometryPoint",
               "features":[
                     "geometry":{
                        "x":-8918372.693449495,
                        "y":4923226.038599581,
                        "spatialReference":{
                           "wkid":102100
                     "attributes":{
                        "position":{
                           "coords":{
                              "latitude":40.393059099999995,
                              "longitude":-80.115105,
                              "altitude":null,
                              "accuracy":6065,
                              "altitudeAccuracy":null,
                              "heading":null,
                              "speed":null
                           "timestamp":1497552113031
                     "symbol":{
                        "angle":0,
                        "xoffset":0,
                        "yoffset":0,
                        "type":"esriPMS",
                        "url":"https://js.arcgis.com/3.17/esri/dijit/images/sdk_gps_location.png",
                        "width":21,
                        "height":21,
                        "style":"esriSMSSquare"
                     "infoTemplate":{
                        "title":"Your Current Location:",
                        "content":"<b>Address: </b>198 Cluxton Rd, Collier Twp, Pennsylvania, 15106<br><b>Latitude: </b> 40.393059<br><b>Longitude: </b> -80.115105"
I do not know if there is anything in here that would cause this to fail.
Is this an issue anywhere else?
Thank you,
Chris
