Hi All,
The digital places can be set in ArcGIS desktop/Server as shown in the screenshots.
However, WAB fails to do this.
What could be the issue here? How can I reflect the displayed digital places from the desktop/server to the WAB?
Thank you in advance.
Best,
Fatin
Solved! Go to Solution.
Since WAB is linked with AGOL/Portal for ArcGIS, you need to configure pop-ups in web map.
Did you check Configure pop-ups—ArcGIS Online Help | ArcGIS .
To configure the attributes within the field or fields you want to display, click the Configure Attributes link. Select which fields you want to display. You can also select a field to change its alias, order it, and format it. For number fields (such as population), select the number of decimal places to display and whether to use a 1,000 separator.
