WAB 2.1 authorizedCrossOriginDomains in config.json how to set
4678
11
08-09-2016 11:23 AM
DavidColey
Honored Contributor
Hi - there is a json key value pair in the config for the WAB
"authorizedCrossOriginDomains": [],
Is this set the same way we set corsEnabledServers in the api e.g.
esriConfig.defaults.io.corsEnabledServers.push("agsdev.scgov.net");
Thanks-
David
RobertScheitlin__GISP
Thanos Of Titan,
  Sorry I am not a Portal user so I do not have that info. Maybe  Derek Law​ would have some input on the portal component.
DerekLaw
Esri Esteemed Contributor
Hi Robert,
Apologies for the late reply, I was out on vacation the last couple of weeks.
@Chris: Can you please see my response to your thread on this topic here,
Why wab dev 2.0 doesn't work with portal but 1.3 version does?
Derek
