Using the Edit Widget to create Polygon records that have automatic area calculations
831
05-28-2021 04:40 PM
Henry
Occasional Contributor II
Hi all,
I'm working in an ArcGIS Enterprise 1.8.1 deployment at an organization focused on invasive plant species inventory and treatment.
We have a couple of Feature Layers that are set up for field data collection through Survey123 that automatically calculate the area of polygons entered through the form. (This is accomplished by a formula in the calculate column of the XLSForm).
However, I would also like to be able to create new polygon records for that feature layer through one of our Web App Builder apps. I can add new polygons with the Edit widget, but the handy area calculation present in the Survey123 form doesn't work across the two platforms.
Is there some way I can have it so that any new polygon created for that Feature Layer automatically generates the area in a specific unit? Being able to do so would drastically help us with some inconsistencies that are appearing in our data when it comes time for reporting.
Thanks!
Henry
DavidMurray_ODWC
New Contributor III
The Draw/Sketch widget has something like that functionality.  (Not very helpful, I realize, but I was browsing others' questions and stopped to look.)
Tags (1)
