Service Proxies for ArcGIS Online Routing and Traffic
4331
12
10-25-2016 07:16 AM
deleted-user-CQZbjNeBXm49
Hi All,
Please I need some help using the service proxies in my WAB dev 2.1 web apps in the "Direction Widget", I have tried using the generated services proxies but all I get is an error in the configuration settings, also tried doing it via "proxy.js" but this prompts users to login before they can make use of the direction widget.
Can anyone assist me in successfully implementing the "Direction Widget" without users needing to Login?
Baba
Hi Derek,
Thanks for the reply, I have gone through the blog post and now having new sets of errors like "Error generating token" and/or "You do not have permissions to access this resource."
This occurred using an administration account within my organisation
While the later occurred after I had created a publisher account outside the AD
Do I need to activate or license something before I can get permissions to the resource?
Cheers
Baba
Solution:
Activate Network Analysis License for the credential to be used
However, now that it works I get the "Please sign in to continue" prompt, even after sharing the item as "Everybody"
Thank you Derek ‌ and Robert ,
I was able to figure it all out now, rather than using "https://route.arcgis.com" in the <serverUrl>, the full service need to be in there as seen in the image below
Thank you
Baba
