Please help with Create widget error: themes/FoldarbleTheme/widgets/HeaderController/Widget
2368
15
03-07-2019 09:14 AM
RudieWatzig
New Contributor III
Good morning,
I have noticed that my WebAppBuilder application (ArcGIS Web Application ) gets the following error when being opened only in Internet Explorer:
Where do I begin to sleuth out this error?
RobertScheitlin__GISP
See if this thread helps. There was an Windows Update that made the use of double backshashes in a path no longer work in IE.
https://community.esri.com/thread/229836-webappbuilder-bug-with-custom-icons-on-widgets-and-ie
RudieWatzig
New Contributor III
It partially helped.  My app does load now after replacing all the \\ with / for file locations, however the header still does not load...   interesting.
by Anonymous User
Not applicable
Did you try downloading any of the patches for the Windows updates linked below?
RudieWatzig
New Contributor III
My computer is up to date.  I tried downloading and manually installing, and two said they were not applicable to my machine, and the third said I already had that update patched.
Rudie,
   Did the error in the console change? Did you replace all the \\ in the whole config.json?
RudieWatzig
New Contributor III
Yeah, it's showing no errors now in the console.  Not as far as I can tell.  Here's the test web app I am using where I removed the //
Rudie,
   Your header loaded for me in IE11 using that link.
RudieWatzig
New Contributor III
Interesting, not here.  And I'm all up to date.
Here is what I get. DId your clear your cache?
