Photo resizes
1464
12-06-2016 12:31 PM
AmyKlug
I imbedded a photo (of a legend) into the "about" widget and the strangest thing happens, every time I leave that tab to go to another tab and come back the photo get's smaller. Do this several times and it almost disappears. ????? anyone seen this before or how to fix it?
RobertScheitlin__GISP
Amy,
   I am not seeing that issue at all. What version of WAB are you using?
AmyKlug
I am using 2.2. my images are over 400*400. When I make them smaller they work fine. I think I can break the legend up into smaller pieces, I hope.
Amy,
   The widget dialog warns that images larger then 400 x 400 will be automatically resized. This is the function in the about widget Widget.js that does that: You could always comment out some code.
      _resizeContentImg: function() {
        var customBox = html.getContentBox(this.customContentNode);
        if (this._hasContent) {
          html.empty(this.customContentNode);
          var aboutContent = html.toDom(this.config.about.aboutContent);
          html.place(aboutContent, this.customContentNode);
          // single node only(no DocumentFragment)
          if (this.customContentNode.nodeType && this.customContentNode.nodeType === 1) {
            var contentImgs = query('img', this.customContentNode);
            if (contentImgs && contentImgs.length) {
              contentImgs.style({
                maxWidth: (customBox.w - 20) + 'px', // prevent x scroll
                maxHeight: (customBox.h - 40) + 'px'
