Opening a widget at startup with its visibility set to false.
1207
09-21-2016 03:59 PM
arunchanumalla
is there a way we could open a widget at startup with its visibility set to false ? Basically, i would like to apply a filter widget on startup without any interaction with user..
RickeyFight
MVP Regular Contributor
There is if you are using the developer edition
Look at this example:
GitHub - cmndrbensisko/LocalLayer: The LocalLayer Widget for ArcGIS Web AppBuilder is intended to al...
LocalLayerWidget and AccessifizrWidget
    "widgetOnScreen": {         "widgets": [             {                 "uri": "widgets/LocalLayer/Widget",                 "visible": false            },         ...        ]     }
arunchanumalla
Thanks Rickey,
May be i did not explain clearly, The challenge was to have a widget not visible and at the same time the application starts the widget on
startup. We cannot have both Visibilty =false and openStartup = true . I mean the Visibility setting takes precedence over the openAtStartup setting.
So , to overcome this problem i just set inPanel=false in the Manifest.json file of the widget.
Appreciate your effort in trying to help me
A
