Open a Bookmark in a Web App using URL parameters?
1408
5
02-04-2020 05:29 AM
jchester73
I have created a web app with WebApp Builder which uses several bookmarks. Is it possible to have url parameters which would open the app to a specific bookmark showing in the map area?
RobertScheitlin__GISP
Janet,
   A bookmark is just a saved extent in the map, so yes you would use the extent url parameter:
Use URL parameters—Web AppBuilder for ArcGIS | Documentation
jchester73
Thank you, I will look into this!
IanLadd
Is there a way to simply link to the bookmark? I've been using bookmarks to save layer visibility and would like to have a url that just points to a bookmark with a predefined layer visibility and not have to do it in the url if that makes sense
@IanLadd No there is no url parameter for that.
JoshuaHouston
The documentation does not include how to change the bearing. Is that possible?
