Layer List auto start location change
4797
12
09-03-2015 08:14 AM
LeoLadefian4
How do i set the location of the Layer List when auto start is set to true.  The Layer List covers up the zoom in and out buttons in the Launchpad Theme
RobertScheitlin__GISP
Leo,
  There is no configuration for this so you have to edit the
[install dir]server\apps\[ap number]\themes\LaunchpadTheme\panels\LaunchpadPanel\Panel.js
When you open this file find this function:
setPosition: function(position){
      var style, box, row, col, size;
      box = this._getLayoutBox();
      size = Math.floor(box.w / (position.width + position.margin));
      row = Math.floor(position.index / size);
      col = position.index % size;
      position.left = (row + 1) * position.margin + col * (position.width + position.margin);
      position.top -= position.margin * row;
      position.left += 50;
      this.position = lang.clone(position);
      if(window.appInfo.isRunInMobile){
        position.left = 0;
        position.top = box.h / 2;
        position.width = box.w;
        position.height = box.h / 2;
      style = utils.getPositionStyle(position);
      style.position = 'absolute';
      domConstruct.place(this.domNode, jimuConfig.mapId);
      domStyle.set(this.domNode, style);
      this._onResponsible();
and add line 11 above
Leo,
        position.left = 0;
LeoLadefian4
Thanks, I was looking under the config.json for the widget layerlist.  wrong spot i suppose.
Leo,
   You are correct, the config.json will not help in this case as the widgets position is calculated in the code at runtime and is not stored in the config.json.
LeoLadefian4
This is what I'm looking at in the code, a little different than what you show.
_setPositionStyle: function(a) {
            var b;
            this.position.zIndex && (a.zIndex = this.position.zIndex);
            this.position.left = a.left;
            this.position.top =
                a.top;
            this.position.width = a.width;
            this.position.height = a.height;
            b = h.getPositionStyle(a);
            e.mixin(b, a.borderRadiusStyle);
            c.set(this.domNode, b)
        onWindowResize: function() {
            var a, b = {};
            window.appInfo.isRunInMobile ? (a = "map" === this.position.relativeTo ? this.map.id : window.jimuConfig.layoutId, a = f.getMarginBox(a), b.left = 0, b.top = 0, b.width = a.w, b.height = a.h, b.zIndex = this.position.zIndex) : (b = e.clone(this.position), "minimized" === this.windowState && (b.height = this.titleHeight));
            b = h.getPositionStyle(b);
            b.position = "absolute";
            "auto" === b.zIndex && (b.zIndex = 0);
            c.set(this.domNode, b);
        setPosition: function(a, b) {
            var d, g, k;
            b || (b = "map" === a.relativeTo ? this.map.id : window.jimuConfig.layoutId);
            d = f.getMarginBox(b);
            k = Math.floor(d.w / (a.width + a.margin));
            g = Math.floor(a.index / k);
            a.left = (g + 1) * a.margin + a.index % k * (a.width + a.margin);
            a.top -= a.margin * g;
            this.position = e.clone(a);
            window.appInfo.isRunInMobile && (a.left = 0, a.top = 0, a.width = d.w, a.height = d.h);
            d = h.getPositionStyle(a);
            d.position = "absolute";
            "auto" === d.zIndex && (d.zIndex =
                0);
            p.place(this.domNode, b);
            c.set(this.domNode, d);
Leo,
  It looks like you are working with the minified code. That is not a problem. Here is the change for that version (line 8):
            var d, g, k;
            a.left += 50;
                0);
IslamSaeed1
Hello Robert,
Actually i am having a similar inquiry , i want the widget to open on the right side of the screen but when searching the mentioned block of code i didn't find that exact section, i am attaching my panel.js file for your reference
Islam,
  You are going to have a really hard time trying to make any code changes to a minified/uglified code like that. This is why you should be using WAB Developer version.
IslamSaeed1
I am using the portal for arcgis 10.6.1 out of the box WAB so there is no way to tweak this ?
It's not impossible just extremely difficult.
