Launchpad Theme Search widget not working on mobile
3567
6
07-15-2015 12:18 PM
FrançoisFilion-Rouillier
Launchpad theme is a very great and good looking template for WAB. Tough, on mobiles (even in the preview tab on desktop), it's impossible to enter the search widget (we can't write anything in the search bar).
The problem occurs on iPhones, Samsung Galaxy. It works on iPads because it's using a desktop interface.
Is it a bug?
JianWang3
Yes, it is a known bug and has been assigned an issue to it. It will be fixed soon.
JianWang3
RobertScheitlin__GISP
Jian Wang
Does this bug also include the fact that you can not use the measurement widget on mobile devices as the measurement widget does not have a minimize that will allow you to return to the map to start drawing your measurement?
MaryEllen_Perko
Occasional Contributor II
Hi.  Regarding the comment about the measure tool behavior... this is also a problem for geoprocessing tools.  The UI form covers the map and you can't minimize it to interact with the map.
Thanks.
LemaoWu
Robert / Mary,
This is a known limitation of Launchpad theme on small size screen devices. We're improving it and it should be available in Developer Edition 1.2. But for the Online version, it has to be in the next update unfortunately.
LemaoWu
François,
This bug (impossible to enter the search widget in Launchpad mobile theme) has been fixed in the latest Online update. Please have a try again and let us know if any problems. Thanks.
VHolubec
This bug, still occur in WAB Developer 1.2 and 1.3 - when click to Search, the Keybord is just slide up and down immediatelly. Please when this will be fixed in WAB?
Thank you.
Vladimir
