Label, rounding decimals, with text
830
06-15-2022 06:44 AM
ScottJones1
I am trying to build a WEBAPP with various mountain bike trails. I have created some circuits so the team coach can determine which groups should ride which circuits. The pop ups have reduced the distance decimals to 1, but the Labels do not? I tried to use the round(feature, number) but got a NaN?
Is there a way to do this? the same thing happened in ArcPro when I added distance to symbology..
The field is calculated from mileage. If it were a one time deal I would just create a text field, but I imagine building more trails and ..... if I had to do that each time it would be a pain.
I would also like to add text? so instead of 'Circuit 1  7.87387483647364' I could display Circuit 1; 7.8 mi
JohannesLindner
MVP Alum
You will have to create an Arcade expression for that.
Before:
Create a label expression:
"Einleitung " + $feature.OBJECTID + ": " + Round($feature.QErlaubt, 2) + " m³/s"
// or, with newer syntax:
`Einleitung ${$feature.ObjectID}: ${Round($feature.QErlaubt, 2)} m³/s`
After:
In Pro, it's the same.
Before:
After:
Have a great day!
Johannes
