Is it possible to launch a widget from the default popup info window?
1436
13
06-11-2019 07:51 AM
Lake_Country_GIS
I would like to launch a custom widget from the default popup info window in a WebAppBuilder app (add a button or link). Is this possible?
Thanks in advance,
M
RobertScheitlin__GISP
Add your feature action to the jimu.js\featureActions folder and then add your action to the main.js in the jimu.js\featureActions folder.
Yes for that you should add a custom feature action to your widget.
https://developers.arcgis.com/web-appbuilder/guide/create-a-feature-action-in-your-widget.htm
Lake_Country_GIS
Thanks Robert.
I can add this to my own widget, but what about adding it to the default ArcGIS Online identify popup window?
Lake_Country_GIS
Worked like a charm. Now, is it possible to launch/expand a custom sidebar widget as well?
Sure just get your reference to that widget and open it.
Lake_Country_GIS
OK, the widget launches, however, my custom widget requires the sidebar to be opened. And, I would also need to close the info-window. Is there a way to expand the sidebar?
WidgetManager.getInstance().triggerWidgetOpen('widgets_PropertyReport_Widget_48')
See demo here:
https://www.lakecountry.bc.ca/maps/maps/
Lake_Country_GIS
Once again, works like a charm, however, do get a JS error:
init.js:114 Error: Tried to register widget with id==widgets_PropertyReport_Widget_48_panel but that id is already registered
Is that widget configured to open at startup?
